While driving it sounds like it is in the wrong gear
2008 MERCEDES BENZ E350
125,000 MILES • 4WD • AUTOMATIC
PATANDPEGGY
Someone said it sounds like the rear differential.
Mar 20, 2019 at 4:57 PM
JOETECHPRO
  • 705 POSTS
Hey PATANDPEGGY,
Does it shift through all gears correctly but you have an abnormal noise?
Does it have a lack of power or drivability issue or just the noise?
If you can describe the noise a bit better for us we can start narrowing down possible causes.
What speeds do you get the noise? is it worse under acceleration/deceleration? Does it get worse when going around a bend?
Please give as much information as you can and we will go from there.
Regards, Joe
Mar 25, 2019 at 9:15 AM
