Welcome to 2CarPros. The primary grounds are from the battery to the block, then from the battery to the body. There should also be a strap from the engine to the body. The rest of the grounds are spread throughout the van close to each component as the body of the van is used as the ground return. Is there a particular item or items you are having a problem with?
Jul 6, 2019 at 10:49 PM
