You have something else going on. There are too many conflicting fault codes, so it looks to me like many of them were set due to someone working on the car while the ignition switch was on. Simply unplugging connectors, especially to sensors, will cause the multiple computers to detect those actions and set fault codes when a defect doesn't actually exist. They do create a lot of confusion though.
Where I would start is by erasing all the codes, then see which ones come back on their own. The next step is to describe the symptoms or problems you're working on. We can ignore heating and AC system fault codes, for example, if we're looking for an engine running problem.
Once you erase the codes, tell me which ones come back and I'll do my best to help you figure out the causes. For the "P", (powertrain) codes, you can also go here:
https://www.2carpros.com/trouble_codes/obd2
to see the definitions, or I can interpret them for you. We don't have listings for "B", (body), "C", (chassis), or "U", (communication) codes, but I can find them online and see what they refer to.
Mar 20, 2022 at 7:38 PM
