check engine light is on?
2004 FORD F-150
214,438 MILES • 4.6L • V8 • 4WD • AUTOMATIC
BROYLES883
I was installing an LED light bar today when I accidentally touched the positive terminal on the battery while the wrench was on the ground screw. now my gauge cluster is showing the e-brake light thesis light and the maintenance now light and the check engine light are on and the truck is running like it is missing.
Feb 18, 2018 at 9:28 PM
Start by checking all fuses here is a guide to help you see what you are in for
Here are the fuse panel locations and identifications
Also run the codes to see what comes up
Feb 21, 2018 at 10:42 AM
GDINMAN
I had filled up my vehicle with gas and drove about 80 miles on a trip. While driving back home, the truck started missing while excelerating. This has been several days ago and the truck is still missing really bad. The service engine soon light has not come on. I took it and had it hooked up the a computer and it did not show anything. What could possibly be wrong and what should I do to try to get it repaired?
Sep 9, 2020 at 5:30 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Maybe bad gas it was O.K. then gased up and miss. Maybe water in fuel or was fuel Ethenol?
NDNGRL
Yesterday our pickup's check engine light came on. Everything was fine. Had put on computer which showed no codes or problems. Check engine light went off yesterday evening. Had rained a lot yeterday and during day engine seemed to start to miss, like maybe water in the gas tank. We did have to drive through some water but maybe four inches deep and not driving fast. Today, ran a few errands and check engine light came back on. No misses, this stopped yesterday evening. Seemed okay. While turning a corner on my way home the truck just died out. Moter turned off. Steered off the road and restarted truck with no problems. Came home, which was about 7 miles and was pulling into driveway it died again. Not sure about this now. Have any ideas?
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
ALM
2004 Ford F-150 Triton 4.6L. 56,000 miles, Battery died 2 weeks ago, replaced it and ever since "check engine light" has been on. I disconnected negative battery cable for 15 minutes, still on. It also shuts off at idle or turns, not idling as high as it should. No change in idle speed when A/C is turned on/off.
Sep 9, 2020 at 5:31 PM (Merged)
Good evening.
Pulling a cable does nothing. It fixes nothing. All it does is make the ECM forget the code as it will return.
I do need the code that is set. From your description, it sounds like the idle air control.
JAMESGAITHER
I have 2004 f150 xlt in which the battery went out. I have replaced battery but now trucks is idoling wrong and sometimes dies when i slow down after driving. I have been told it was the computer and it needs to be reset. I went through the owners manual of how to reset computer but it did not work and to boot a light has come on the dash. what is this light ? it looks like and engine is this the check engine light or emmisions light?
I would really like to fix this problem so I feel it is either the computer is not set or I must have a vacuum leak some where. Any suggestions?
BLACKOP555
  • 10,386 POSTS
usually after the computer is reset after hte battery is connected it has to be driven for about 50 - 100 miles to readjust to your driving habbits again. give it some time and if that doesnt help post back.
JOHNBUG
crossed plug wires changing them out and now service engine soon light is on...corrected wires and need to reset light
CJ MEDEVAC
  • 11,004 POSTS
I do not know your rig!----I usually stay with stuff I know well...I answer in the Jeep CJs a lot.
Many times, disconnecting the Battery for a few minutes will reset stuff!
Saw you had been waiting, I figgered I'd Try!
The Medic
Merry Christmas!....Let me know if I got lucky!
GSLRIDER
  • 4 POSTS
I have a check engine light comes on once in a while, mostly in cold weather. I have been able to read then erase with my scanner. Now my scanner won't work on my truck. It works on others. Could I have a bad pcm that isn't sending out the codes?
Thanks for your help.
JDL
  • 16,098 POSTS
Pin 16 at the datalink connector, does it have voltage? Hot all the time.
GSLRIDER
  • 4 POSTS
I'll have to check. What should I read, 12volts?
JDL
  • 16,098 POSTS
close to battery voltage.
GSLRIDER
  • 4 POSTS
Have to give me time to check it. What if I don't have voltage? Is the cpm bad or is it fused?
JDL
  • 16,098 POSTS
It's a fused circuit. below
GSLRIDER
  • 4 POSTS
Okay. Will check it out. Thanks.
JDL
  • 16,098 POSTS
Let us know what you find.
PADA4140
  • 8 POSTS
No OBD on my 2004 F150,Tritron 4.6. Truck has 55000 miles on it.When you hook up the OBD it reads not reading data,please try again. I have had several attempts to bring this Truck to repair places but they cannot help. The Check Engine Lite is on but I cannot read the Computer????? Any help???? It was at the Dealer last year for an EGR valve and came on again just recently. I cannot get it smogged . Thanks.....
MIKE H R
  • 3,094 POSTS
Has the battery been disconnected lately?
PADA4140
  • 8 POSTS
No the battery is the original, the Truck sits most of the time....Thanks
MIKE H R
  • 3,094 POSTS
if the battery went dead or the battery has been disconnected, the computer will not completly reset until the vehicle has been driven appox 50 miles. disconnect the battery and let it sit for about 10 minutes. then reconnect the battery and drive the vehicle. it does not have to be done all at once. the computer should reset itself thenafter it has been driven, if the battery is disconnected and then tried to scan sometimes it will come up not ready or can not read .
PADA4140
  • 8 POSTS
The battery never has gone dead. I disconnected it for 15 minutes and them drove it to work and back (60) miles. I still cannot read the OBD, it says not communicating when we hook it up.......Thanks
MIKE H R
  • 3,094 POSTS
check the connecting pins for the obd to see if one is bent.
Sep 9, 2020 at 5:32 PM (Merged)
PADA4140
  • 8 POSTS
I CHECKED THE PINS AND THE FUSES UNDER THE HOOD, EVERYTHING SEEMS TO BE OK, I GUESS MY NEXT STEP IS THE DEALER, SEEMS NO ONE HAS THE ANSWER THIS ONE....Thanks....Paul Anania
MERLIN2021
  • 17,250 POSTS
I can't find the diagram right now but google obdII and get the diagram that shows the connector and the pins...check for the power and ground pins and check them both!
NOS
  • 320 POSTS
well there is a fella that is dicourged. Have you check the main body ground at the battery? just a question grounds are real important on fords 8) NOS
PADA4140
  • 8 POSTS
I am at my wits end on this Truck, the pin has power the grounds seem good, the check engine lite remains on and this Truck has been to the dealer 3x for check engine lite, every time it cost me at least $300 for repairs. Last time the EGR valve went bad. I bought an OBD to do the work myself and its possible that the last time ity was at the dealer, they did something to the pin???? In any case its going to a different Ford dealer....Thanks for the help.ps do you want to buy a cheap 2004????? just kiddin
NOS
  • 320 POSTS
it is possible that the computer went south on the diagnosis part. i have run across some of thoes trucks the still have both ports on them the one under the hood and the OBD II when the OBDII wouldn't work the other one would.( just a thought )darn things can get agervating.and on a deal like this one not being there makes it harder to figure out. does the truck run poorly? i have seen a simple thing like a vaccum leak bring on a check engine light.well anyway good luck and sorry we couldn't help with this one 8) NOS
https://www.2carpros.com/forum/automotive_pictures/10147_tri_3.jpg
PADA4140
  • 8 POSTS
No truck runs great other than the check engine lite, I will keep you in the loop after the dealer repairs....Thanks Again........
PADA4140
  • 8 POSTS
Ok, took my truck to the dealer,he said that the 04 and 05 F150 has a (KAN)? TYPE READER for the computer that wont read the OBD11?????They said they read the codes fine. The check engine lite was a fuel pressure sensor (line) ? THAT cost $348 bucks. I tried my OBD11 again after I picked up the truck and it still wont read. Is there a OBD that works on my 04????? Thanks....Paul Anania
PADA4140
  • 8 POSTS
Thanks for everyones help in solving my OBD 11 reader,please inforn your readers that the current OBD 11 will not read correct on the 04 and 05 F 150 Pick Up Trucks. But a Can reader will do the job.......Thanks again....Paul Anania
BAXTER1
I cleaned the throttle body like you suggested and now it idles and runs fine..Thanks ..But now the engine light stays on all i did was clean the throttle bore with carb cleaner..Any more ideas..Thanks Mike
Sep 9, 2020 at 5:33 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
Please respond to your original question when you have a follow up or no one is going to know what you're talking about.
Have the codes read and see what it is. You may have had something unplugged and turned the key on.
MWVATOUR
engine light comes on when starting truck/if let truck sit it slowly dies and truck stalls....when I put the truck in drive and drive away the engine runs rough...engine light is still on.....recently replaced cam sensors in motor
and fuel pump and secondary fuel pump and replaced inertia switch...????? Computer registers different info each time it is hooked up to truck...
CJ MEDEVAC
  • 11,004 POSTS
See my profile,
I know little about computer cars, BUT this is what I do when I have to mess with family and friends rigs. (I have Real Jeeps, CJs, No Computer)
Autozone and Advance Auto will scan your rig for codes, FOR FREE!!!....Engine light on, means you have a CODE(S)
They can probably also set you up with what you need, a lot of times they will show you where these sensors are located........On occasion, I have seen them help you with the issue in their lot!
Let me know what they find
And that you are now fixed!
The Medic
