Ground strap at fuse panel diagram needed
2002 SATURN SC2
148,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
ZULMIRAORION
Ground strap at fuse panel has disconnected and fuel pump won't kick on. since I can't find where to reconnect it I need diagram or pictures please.
Jul 29, 2021 at 12:48 PM
The fuse box isn't grounded. I'm not sure exactly what has happened.
As far as the grounds, I attached the ground distribution for the entire vehicle below. I highlighted everything related to the fuel pump. Let me know if this helps.
Also, let me know if you have other questions or if there is something I can do to help.
See pics below.
Jul 29, 2021 at 10:09 PM
