The first time each day I start the engine, there is a grinding sound for about 3 seconds. Then it goes away and does not recur on subsequent startups the same day.
The Hyundai dealer tells me he is certain it is the timing chain, which needs to be replaced. A non-dealership mechanic says in his 30 years of car maintenance he has never seen a timing chain fail. He believes the cause of the grinding sound is the oil draining from the engine compartment overnight. The sound goes away as oil flows back into the engine. This mechanic does not advise making any repairs.
A friend tells me the 3.6-liter Genesis motor in my car is a zero-clearance engine and if there is a failure (tooth slippage or breakage) it is catastrophic (valves hit pistons).
Can you shed any light on this situation? Should I replace the timing chain? Or should I continue to drive the car as it is and monitor the problem?
May 12, 2024 at 3:54 PM
