For the past few weeks, whenever I start my car and accelerate (5 MPH to 10 MPH) there is a grinding noise (1 second sound) happening under my brake area. I took it into a shop and told me that my front brakes and rotors were a bit worn. So my front was replaced and went to pick it up and the grinding (same as usual) happens again. Though it may be a one time deal but has happened again when I drove a second time.
Here what was done to the car:
Checked brake fluid for contamination and moisture.
Inspect all Hydraulic lines and Hoses. Inspect Calipers and Wheel Cylinders
Inspected master cylinder and cap. Cleaned dirt out and flush fluid out of master cylinder, calipers and wheel cylinders until cleaned.
Add new brake fluid as needed. Road test drive.
So again, after all of this, the grinding, same as it was, is still happening.
Feb 27, 2021 at 3:02 PM
