No noise when coasting. When accelerating there is a grinding noise. It is similar to a wheel bearing going bad but it is not that. Only makes itself known when the gas pedal is used. Sounds like it is in the front. Latest check up the mechanic had to add two pints to the front differential.
Nov 9, 2017 at 7:40 AM
