Grinding noise in the rear while driving
2001 FORD TAURUS
260,000 MILES • 6 CYL • AUTOMATIC
MARGIE OWENS
When I drive it sounds like a rubbing or grinding sound in the rear.
Nov 2, 2019 at 10:30 AM
This vehicle is known for failing hub bearings. I assume you have rear drums so I attached the procedure in case I am correct. However, we need to know if this noise is louder when turning or corning or it is just pretty constant? Does it get louder when you drive faster or is the same no matter how fast you are going?
Here is a guide that takes your through the most common causes of these noises:
https://www.2carpros.com/articles/vehicle-grinding-noise
If none of this seems to fit, you will need to get a recording of the noise so we can get on the same page. Thanks
Nov 2, 2019 at 5:53 PM
