I bought the truck about a year ago with a brand-new engine and transmission. The truck has a 6-inch Fabtech lift installed but is otherwise stock. Grinding only started in the last couple of months and seems to be getting worse over time. Shocks, tires and brakes were all recently replaced to no effect. Upon visual inspection cv axles, bushings and tie rods seem fine but I'm no expert. Not sure what else could be causing the issue. The last shop I took it to a kid that was significantly younger than my truck trying to diagnose the issue and couldn't figure it out. Any suggestions on what to look for? Grinding is loud and metallic, and it sounds rotational.
Aug 24, 2022 at 4:32 PM
