Recently I have noticed a grinding noise on idle and it is still present when accelerating and decelerating. I have changed the crank pulley, belt tensioner, belt and put a new power steering pump on but the noise still seems to be coming from the steering pump. Sounds like a whirring bearing. Am I missing something? When you take the belt off and run the engine the noise is gone so I only have alternator, water pump and A/C pulley left to check but it sounds like the whirring is coming from higher up near the pump. Just need some experienced guidance if anyone has come across this before.
Aug 19, 2019 at 11:54 AM
