After vehicle has warmed up transmission is hard to shift and grinds gears
1994 MITSUBISHI 3000GT
60 MILES • 3.0L • V6 • 2WD • MANUAL
UNCLEBIFF
  • 37 POSTS
it seems to shift fine when the engine is cool, but when it warms up it grinds the gears really bad very hard to shift.
Nov 3, 2020 at 7:36 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You didn't really specify how many miles are on the transmission but I would suspect the synchro's are wearing or worn out. Each gear in the transmission has a synchro along with it to act as a buffer when shifting between gears. Also, you might notice it more once the car is warm due to the transmission fluid getting warmer with temperature and then the oil is more thin creating less of a buffer. Hope this helps and thanks for using 2CarPros.
Nov 3, 2020 at 7:51 PM
