Grinding when driving twenty to thirty mph
2000 DODGE NEON
192,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
UNKNOWNISSUE
  • 10 POSTS
I have completely changed the transmission. I have check the CV joints and drive shaft, hubs, brake calipers, brake pads. changed my filter on my transmission and my oil two times. put new alternator and mounts all around and at twenty to thirty mph not every time, but most times it will grind like an metal on metal grind .my car is an three speed .please if you have any idea I am out of them? Also, when it grinds if I let off the gas and and ease back into it stops.
Nov 13, 2017 at 11:49 PM
SATURNTECH9
  • 30,869 POSTS
How did you check the hubs?Just by seeing if they had play in them?
Nov 16, 2017 at 12:31 PM
UNKNOWNISSUE
  • 10 POSTS
Well I've checked the pads and calipers the rotor I have looked over it not therally
Nov 16, 2017 at 11:26 PM
SATURNTECH9
  • 30,869 POSTS
Do you have a jack and jack stands so we can have you check the front wheel bearings?
Nov 17, 2017 at 6:50 AM
UNKNOWNISSUE
  • 10 POSTS
This is the noise its making and yes I do
Nov 19, 2017 at 12:54 AM
UNKNOWNISSUE
  • 10 POSTS
Do you have an messenger for Facebook I'll just send you the video if what it does and sounds like
Nov 19, 2017 at 1:52 AM
SATURNTECH9
  • 30,869 POSTS
Put the front of the car on jack stands so both front wheels are off the ground on a flat level surface.Put the ebrake on and put the car in neutral.Then put one hand on the coil spring and spin the tire as fast as you can with the other hand if the bearing is bad you should be able to feel the bad bearing in the coil spring.Compare each side to each other.
Nov 19, 2017 at 7:11 AM
UNKNOWNISSUE
  • 10 POSTS
Did you see the video
Nov 22, 2017 at 12:00 AM
SATURNTECH9
  • 30,869 POSTS
Yes but I really couldn't tell much from the video did you try what I asked you to do?Even if I was there in person I would be still trying that.
Nov 22, 2017 at 12:47 PM
UNKNOWNISSUE
  • 10 POSTS
Alright ill do that today any other opinions on what it could be
Nov 24, 2017 at 12:37 AM
SATURNTECH9
  • 30,869 POSTS
That's my biggest suspecr
Nov 24, 2017 at 11:43 AM
