I have the vehicle listed above z18xe. If I press the accelerator a bit while starting it idles until I let go of the pedal. New fuel pump-crank/cam sensor (Buick) ignition coil. Fuel pressure around 30 PSI. There is a slight of liquid/oil at the thermostat/connector. Appreciate insight.
Sep 26, 2023 at 10:59 AM
