Buzz in radio that varies in sound level
1992 DODGE DAKOTA
232,000 MILES • 3.9L • 6 CYL • 2WD • MANUAL
GARYSIMPSON
  • 22 POSTS
Have a buzz in radio that varies in sound level is there suppose to be a ground on the gas tank. Also gray smoke on start up which varies on how much at different starts.
Jan 2, 2019 at 7:19 AM
Good morning,
Check the charging system voltage. make sure it is 14 to 14.5 volts. Then switch your scale to AC voltage and measure that as well.
No, the fuel tank does not have a strap. all components on the tank have external grounds.
The smoke could be oil burning off from worn valve seals.
Jan 2, 2019 at 7:29 AM
GARYSIMPSON
  • 22 POSTS
Changed alternator radio buzz quit but started buzzing again.
Jan 16, 2019 at 7:54 AM
Did you verify the voltage as I suggested before changing it?
Jan 16, 2019 at 8:05 AM
GARYSIMPSON
  • 22 POSTS
Sorry still had a grd but ya'll are good.
Jan 16, 2019 at 8:30 PM
GRD?
Please explain.
Jan 17, 2019 at 2:51 AM
GARYSIMPSON
  • 22 POSTS
Well kind of lost radio buzz. alternator was bad replaced buzzing stopped for a day. started buzzing again, disconnected negative hooked light between post and lead it light up pulled every fuse and reading 12 volts between battery negative post and lead confused. Thanks Roy.
Jan 17, 2019 at 3:56 PM
Okay, using a test light is not a way of checking for a draw. You need to check for current flow. that is what causes a drain, not voltage.
https://www.2carpros.com/articles/car-battery-dead-overnight
Jan 17, 2019 at 3:59 PM
GARYSIMPSON
  • 22 POSTS
Okay, how do i do that?
Jan 17, 2019 at 4:00 PM
It is in the guide I sent you.
You are looking for 50-75 milliamps. You need an amp meter to do this test.
Jan 17, 2019 at 4:02 PM
GARYSIMPSON
  • 22 POSTS
Okay, I will let you know. Thanks
Jan 17, 2019 at 5:19 PM
You are welcome.
Always glad to help.
Jan 17, 2019 at 5:31 PM
