Grating noise when power steering is not engaged
2005 TOYOTA CAMRY
160,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TURTLEJAMES
Car emits a low grating humming noise coming from the driver's side engine area roughly behind the air box. Noise goes away completely if the steering wheel is engaged (turned). Noise happens while parked or driving and stops as soon as you turn the wheel in either direction.
No noise where the power steering reservoir or pump are (passenger side). Power steering working fine with no noise while turning.
Please help. Thank you.
May 22, 2018 at 9:09 AM
This happens for two reasons either the fluid is worn out or the pump is. I would try the fluid first. Here is a video to show you how to flush the system:
https://youtu.be/Mcs3lmu4Wkw
If that does not do the trick the pump will be next this guide will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
May 24, 2018 at 12:49 PM
