I have no spark and the tachometer just sits when I try to start it and no engine light either, but I get fuel to the fuel bar. so I replaced my ignition coil pack and nothing. I replaced the crank shaft position sensor and nothing. then I replaced the ignition module and once again nothing. so I check the connection to the ignition module to see if I am getting power to it and nothing. I did get power with the ignition positive prong and I got 0.12 volts. so maybe it is the CCE power relay next to the fuel pump relay.
Feb 6, 2017 at 9:16 PM
