Got a crank but no start condition?
2007 LEXUS GS 350
180,167 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JOSEO88
  • 5 POSTS
Only cranks but doesn't want to start... changed sparks coils fuel pressure sensor checked starter alternator camshaft and crankshaft are new and it still won't start on me. any help will be highly appreciated. thanks again
Jan 19, 2025 at 7:08 PM
Will it run on starting fluid? If not, we need to see if the engine has spark. This will guide us to the system that is not working.
Please go over this video which will help us see what is going on:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
We should check the fuses with the key on and run the codes.
and
Please go over these guides so we can narrow down the problem, get back to us.
Jan 21, 2025 at 11:06 AM
JOSEO88
  • 5 POSTS
Yes I have spark I injected the intake tube with some starter fluid but doesn't cough on me or try to start I just recently swapped out my fuel pressure sensor... bought it at eBay? Think it's defective?
Jan 22, 2025 at 1:11 AM
JOSEO88
  • 5 POSTS
P0102, P0113, P0118, P0123, P0453, P2135, P2138, P2239, P2241, P2252, and P2256 codes.
Jan 22, 2025 at 1:23 AM
How does the engine sound when cranking? does it have compression? If you upload a short video of the engine cranking, I can tell if it is hurt or not. Also, clear the codes and then crank the engine and rerun the codes, this way we can get the most relevant ones to help avoid confusion.
Jan 22, 2025 at 9:03 AM
JOSEO88
  • 5 POSTS
K, I got you, hold on.
Jan 22, 2025 at 2:39 PM
Yep yep :)
Jan 23, 2025 at 10:55 AM
JOSEO88
  • 5 POSTS
Okay, so, I got it to start w the starter fluid for a split second then turns off I took off the air intake and stuff and checked the fuel rail to see if it pressure going. Cycled the key 3xs n yes squirted out some fuel... so started checking the air n everything looks normal to me I'm guessing spark it has right since I got it to start.. do you it's the fuel pump.?
Jan 23, 2025 at 8:49 PM
That could be, does the engine continue to run as long as you are spraying fluid? If so, then it can be the fuel pump, did you clear the codes and then crank the engine over to see what codes come back, we need to narrow the problem down a little more.
P0102 - Mass Air Flow (MAF) Sensor Circuit Low Input
I would also unplug the MAF sensor to see if it starts. Check out the images (below). Please let us know what happens.
Jan 24, 2025 at 10:29 AM
