good battery bit otherwise electrically not working?
2004 FORD E-SERIES VAN
56,000 MILES • 6.8L • V10 • 2WD • AUTOMATIC
TLP2900
It was running fine. Maybe multiple stops started just fine after each of them except the last one; now it won't start the headlights don't work but the battery has power even under load test. Help.
Feb 19, 2023 at 1:31 PM
Is there anything electrical that works? For example, do the brake lights work or interior courtesy lamps? Does the horn work?
There are several fusible links on this vehicle. I just need to confirm if it is an E350, an E450 and if it is a traditional van or if was it originally sold as a stripped chassis for a body company.
Feb 19, 2023 at 11:06 PM
