Cluster wiring diagram needed?
1998 VOLKSWAGEN GOLF
100,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SCION
  • 41 POSTS
Golf MKIII Cluster wiring diagram
Hello, i need to know which pinout is which for the following:
Power
Ground
Speedometer
Tachometer
Transmission gauge
Thanks
Apr 20, 2024 at 6:39 PM
Sure, here are the instrument cluster pinouts and wiring diagrams for clarity, this guide can help you with the testing.
1- Outside air temperature sensor -G17-, Ground (GND) 1)
2- Engine Coolant Level (ECL) sensor -G32-
3- Terminal 31, Ground (GND)
4- Multi-function indicator memory switch -E109- (reset) 1)
5- Terminal 31, Ground (GND)
6- Multi-function indicator memory switch -E109- (memory) 1)
7- Vehicle Speed Sensor (VSS) output
8- Oil pressure switch -F1-, 1.8 bar
9- 0.3 bar oil pressure switch -F22-
10- Terminal 1/terminal W
11- Terminal 30, battery positive voltage (B+)
12- Terminal 58b, lighting
13- Terminal 15 (B+ with ignition switched on)
14- Open
15- Multi-function indicator mode select switch -E86-1
16- Generator (GEN) warning light -K2-, terminal 61
17- Engine oil temperature sensor -G8- 1)
18- Brake and parking brake warning light -K7-
19- Outside air temperature sensor -G17-, signal 1)
20- Malfunction Indicator Lamp (MIL) -K83-, or glow plug indicator light -K29- (Diesel)
21- Fuel gauge -G1-
22- Left turn signal indicator light -K65-
23- Engine Coolant Temperature (ECT) gauge -G3-
24- Right turn signal indicator light -K94-
25- Headlight high beam indicator light -K1-
26- Input signal, fuel consumption 1)
27- Vehicle speed signal from speedometer Vehicle Speed Sensor (VSS) -G22-
28- Transmission Range (TR) selector lever display (AG4)
1) Only with multi-function indicator -J119-
Apr 21, 2024 at 11:01 AM
SCION
  • 41 POSTS
Thank you. Can you highlight which pin is the power, ground, speedometer and tachometer?
Apr 21, 2024 at 1:47 PM
Sure, there are two power pins one is switched while the other is constant battery.
26- Input signal, fuel consumption 1) TACH
Let us know if you need anything else.
Apr 22, 2024 at 10:07 AM
SCION
  • 41 POSTS
There are 2 plugs, one orange one black. They have the same pin count, but which one do I use?
Apr 22, 2024 at 6:10 PM
I would try either one to see if whatever you are doing will work.
Apr 23, 2024 at 10:04 AM
SCION
  • 41 POSTS
You forgot to mention pin 5 for ground, it's not only pin 3. Also, for anyone else in the future testing oma mkIII, its the black plug, not the orange. So, pin 3 for gnd, pin 5 for gnd, pin 11 to turn on cluster (the power box is not detecting thr cluster) and pin 13 to turn on lights (the power box now detects the cluster)
Jul 8, 2024 at 10:01 PM
SCION
  • 41 POSTS
It's also flashing the oil and temperature light, LOL.
Jul 8, 2024 at 10:04 PM
So, it is working correctly? all good?
Jul 9, 2024 at 9:41 AM
SCION
  • 41 POSTS
Yes, I'm hoping to connect my Arduino to it and work the pins to it, and maybe even use it as my clock. LOL
Jul 9, 2024 at 9:52 AM
Nice work, thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jul 9, 2024 at 9:59 AM
MATTYVANEK
  • 4 POSTS
Hi! I just want to ask, if Scion got them working with Arduino. I want to connect them via Arduino to Simhub, and use them in game... And I need to know if you connect them via the Analog plugs on Ardu, or via Digital (PWM)? I wasn't able to get them working :( So I need to know -> what pins, where to plug 'em and how to setup them :), I have Gauges from 1.4 liter, and on the mainboard is year 1991.
Thanks much guys ;)
Aug 7, 2024 at 12:47 AM
I am not sure, I hope SCION responds :) if not let me know and we can try to help you.
Aug 7, 2024 at 12:32 PM
SCION
  • 41 POSTS
Hey, I was sadly not able to get mine working, but I was able to just have it running on power, however I got my BMW E36 insturment cluster working on my Arduino if you're interested
Reason why I was not able to connect my MKIII was because it needed a custom protocol, which I know Random Science 4K on YouTube knows.
Aug 7, 2024 at 1:28 PM
MATTYVANEK
  • 4 POSTS
Okay, thanks, I'll try it, and let you know :)
Aug 8, 2024 at 12:01 AM
