Going into limp mode
2006 NISSAN SERENA
154,160 MILES • AUTOMATIC
PHILLIP BURKE
(1) The van going into limp mode.
(2) The steering getting tight.
(3) The gear shift getting tight to shift.
Apr 26, 2019 at 7:19 AM
This is common and 9 times out of 10 it is caused by a dirty throttle bore causing the correlation to be lost between the throttle actuator and PCM. here is a guide that will help you fix it:
https://www.2carpros.com/articles/reduced-power-limp-mode
Apr 27, 2019 at 11:39 AM
