Going back and forth from "D" to "O/D"
1999 MERCURY MYSTIQUE
118,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
VANESSA FALIN
Car shifts from first all way through but after it has to hear back down it constantly jumps from drive to overdrive and back and forth, sometimes, will not grab a gear at all then you will have to just cruise at a slow speed and barely push gas to get it to go. Overdrive light does flash on the dash at times when it does this and if you push the overdrive off button on shifter it seems to help some but it will still try to go into overdrive even though you have selected the off button. Please help, we are hoping this is a simple fix.
Apr 30, 2017 at 11:04 AM
There must be a problem with one of the sensors on the transmission. Can you run the codes to see if any show up, here is a guide to show you how.
Please run this test and get back to us so we can continue helping you.
May 3, 2017 at 9:47 AM
