Groaning rubbing sound at twenty kmph to ten kmph while decelerating or when in neutral
2015 HYUNDAI I10
12,000 MILES • 1.1L • 3 CYL • FWD • MANUAL
AMITAVA PAUL
Had run 12,000 miles with my car. Recently after the third service I found a groaning/rubbing sound coming while decelerating or when in neutral at around twenty to ten kmph. I cannot make out the sound when accelerating due to the turbo and when below the ten kmph mark. I had mentioned the service station about the skidding of my vehicle to one side on sudden application of brakes. I also asked them to check the front-left suspension as I once hit a very bad pothole with bursting of the left front tire. They said they did not find any problem with the suspension. Please help.
Mar 12, 2017 at 11:18 AM
HMAC300
  • 48,601 POSTS
check for a shield under car rubbing or the dust shield on disc brake rubbing against rotor. then check tire/wheel for being bent.
Mar 13, 2017 at 7:34 AM
AMITAVA PAUL
I will see to it. Thank you for your help. Another thing what they did at the service station is they did wheel alignment and balancing. Can that be a cause?
Mar 13, 2017 at 7:58 AM
HMAC300
  • 48,601 POSTS
not really unless a wheel is loose and not tightened properly.
Mar 13, 2017 at 8:02 AM
AMITAVA PAUL
Okay. Thanks again.
Mar 13, 2017 at 8:13 AM
It could be an axle bearing that has gone out, here is a guide that may help you.
https://www.2carpros.com/articles/how-to-replace-front-wheel-bearings-and-seals
Please let us know what you find so it will help others.
Best, Ken
Mar 15, 2017 at 12:44 PM
