The Camshaft Position (CMP) Sensor (5.3L VIN T) is located on the center bottom of the front of the engine. Here is the location of the crankshaft sensor which it is more likely to be. You should charge about an 1.5 hours for both, plus parts. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Jun 19, 2020 at 1:32 PM
(Merged)
