2005 GMC Yukon Traction control/abs noise
2005 GMC YUKON
40,000 MILES • V8 • 4WD • AUTOMATIC
CEFUDGE
First, the ABS was active during all braking...8 miles an hour to stop. Also, there was a noise (grinding) during acceleration that stopped after 8 MPH reached. Dealer replaced ABS sensor. The ABS brakes are now working correctly, but the noise is still occuring when accelerating, but stops when reaching 8 MPH. The noise does not exist if I disable the traction control.
thoughts?
Dec 18, 2008 at 3:07 PM
BRIAN 1
  • 1,030 POSTS
any dtc's?does the DIC display any service Stabilitrak message?like not ready or disabled? need more info,there are some bulletins on this problem but not enough info to diagnose.
Dec 18, 2008 at 3:17 PM
CEFUDGE
no warning lights come on...the dash is clean. Just the noise when accelerating. No noise when the TC is disabled.
We just bought this thing used, and have short term warranty with the dealer. Any info will help me out.
thanks for your responses!
Dec 18, 2008 at 3:21 PM
BRIAN 1
  • 1,030 POSTS
also forgot to add check the tire pressure and make sure all the tires are the same size and have the same amount of tread,this WILL make the stabilitrac sys activate.
Dec 18, 2008 at 3:25 PM
CEFUDGE
tires are within 1 pound of each other.
rear tires have more wear than front. I was going to have dealer replace rear tires as part of deal, but changed my mind. I do plan on replacing all 4 tires after winter. maybe I should rotate front to back. But again, the rear tires have noticable wear.
I did try to pay attention to road surface. First thought it was due to wet roads, but the noise is consistant on all surfaces. right now, everything is either wet, snowy, icy, or dry with salt dust! illinois
Dec 18, 2008 at 3:31 PM
