2005 GMC Yukon Too many issues to list
2005 GMC YUKON
56,000 MILES • V8 • 4WD • AUTOMATIC
BRENDALAUN
On my 05 Yukon the RR and LF tire pressure sensor is indicating 0 pressure. How and what can i do besides take it to the dealler? I am on Guam and these mechanics will overcharge me for minimul work.
Also, the a/c system seems ot be failing. The drivers side gets cold air along with the back but the passengers side gets heat. It has been in the shop 3 times for this and these jackass mechanics cant seem to figure it out.
Mar 17, 2010 at 5:52 PM
HMAC300
  • 48,601 POSTS
the tire sensors may be need to be reprogrmmed which a tire store may be able to do but there may not be anyo ver there. so the dealer will have to do it. If i rember correctly it has to be done falirly quick so they should go over the process in the book once more before attempting to do it. the heat a/c thing you can check at the module by seeing if one of hte doors are frozen in place. You can try to move the door to see if it wiill free up to correct the a/c. If not guess where it has to go? yep especially if it's under warranty.
Mar 25, 2010 at 7:12 PM
