2005 GMC Yukon front fan blower intermiitent
2005 GMC YUKON
45,000 MILES • V8 • 2WD • AUTOMATIC
JOSEKING
Rear a/c blows strong. Front passenger/driver hardly ever works. I have replaced compressor relay switch and pulled all relevant CB's with no joy. My research shows this problem to be a common one and a compelling argument could be made that this is an design flaw.
May 12, 2010 at 8:23 PM
SERVICE WRITER
  • 9,123 POSTS
They have issues with blend doors not working.
Those actuators have small plastic gears inside and 1 chipped tooth or small crack leads to erratic operation. If you remove the actuator take the darn thing apart, and at the same time you can manually work the door to see if your symptoms change. But before dissassembling, discconnect the battery for a half hour, this will reset the bend door operation. However, depending on your radio, you may need a code to reset the radio.
May 17, 2010 at 5:32 AM
