Battery light wont turn off
2005 GMC YUKON
65,000 MILES • V8 • 4WD • AUTOMATIC
DAMARVOLOUS1
hi, i have had a problem with my car battery. The light would not turn off. So I changed the battery and I also changed the altenator, brought a bigger ground wire that goes from the altenator to the positive and still i have the battery light on. does anyone have any suggestions on what else could be the problem before i must take it to the dealer.
Jan 15, 2010 at 5:25 PM
Could be a problem with the computer controlled of the field generation of the alternator but did you use an AC Delco unit? cheaper alternators are bad right out of the box. Here is a guide to see if it is charging.
Jan 15, 2010 at 5:28 PM
OIDAVEY
  • 0 POST
Thanks for this post I had this problem had to get an AC Delco unit, all fixed!
Apr 30, 2019 at 5:14 PM
STEPH_CARRASCO
I have a Yukon xl 2003. What would make my Yukon shut off when I hit a bump or railroad track. The doors lock and in lock, ABS and Service brake light and the engine light comes on than the battery light comes on and then the Yukon shuts off.
Apr 30, 2019 at 5:15 PM (Merged)
CARADIODOC
  • 34,306 POSTS
There's no way to diagnose this without standing right by the truck and doing some tests, but given the combination of symptoms, you might follow the smaller battery positive wire to where it bolts to the under-hood fuse box. Be sure that connection is clean and tight.
It's much less common but also follow the smaller negative battery wire to the body and be sure that's rust-free and tight.
The next thing is easier to do than to describe. It involves connecting a test light to various places, then watching whether it goes out or not when the problem occurs. That allows you to narrow down where you're losing voltage and where you're not. A common problem that could be found this way on older GM vehicles had to do with their use of aluminum wire. The connections where they were riveted to the brass strips in the fuse box would corrode, especially when they stuffed the fuse box right above the driver's feet where road salt could reach it. I haven't heard of that problem in many years, but that's the type of thing we would look for.
