2004 GMC Yukon Power cuts off when trying to start
2004 GMC YUKON
75,000 MILES • V8 • 2WD • AUTOMATIC
SCRAPPY14
  • 4 POSTS
I just replaced the battery in our 04 Yukon. After attacehing battery cables to the new battery, I turned the key to the first position to confirm that I indeed had power (Stereo, door locks, lights etc working fine). As soon as I turned the key all the way to ignition all power was immediately lost throughout the vehicle. It never made a crank sound, it just cut power instantly similiar to a circuit breaker tripping. The new battery test out fine. I removed the battery cables and re-attached and power was restored until I tried to start the engine again at which time a repeat of the power loss occured. Could this be caused by a short circuit in the starter casuing a circuit breaker to shut down power? One Note: The battery cables screw into the side of the battery. The negative cable is snug and doesn't move but the positive moves around some, even though the screw is tight and there apperas to be good contact to the battery.
Any help would be greatly appreciated.
Sep 3, 2009 at 10:30 AM
JDL
  • 16,098 POSTS
Did you try cranking in neutral? Also, check the circuits at the starter relay in the power distribution center. When you turn the key to crank, any reaction with the dash lites or dome lite?
Sep 3, 2009 at 11:08 AM
SCRAPPY14
  • 4 POSTS
I didnt try cranking in nuetral. And I just went out to try and after re-connecting the battery I get no power at all. At least with the first few tries I would get power unitl I turned the key to crank. To answer you question I got no reaction with the dome or dash lights before when I tried to turn the key to rank. As soon as I would turn the key all power was immedialtey lost.
Sep 3, 2009 at 11:36 AM
JDL
  • 16,098 POSTS
I'd have to check the feed to and from the ignition switch.
Sep 3, 2009 at 12:01 PM
SCRAPPY14
  • 4 POSTS
What would you (I) be checking for on the feed to and from ignition switch?
Sep 3, 2009 at 12:18 PM
JDL
  • 16,098 POSTS
Solid red wire going to the ignition switch connector, should be hot all the time. Also check ign fuse A-- 40 amp, in the under hood fuse box, that also should be hot all the time. Use a testlite to check for voltage on those circuits.
Sep 3, 2009 at 12:33 PM
SCRAPPY14
  • 4 POSTS
OK. Just got a little more info from my brother who jump started this car before we changed out the battery. He said he did not connect the jumper cables to the remote neg and pos terminal (as recommended in owners manual) but instead he connected directly to the battery cable connections at the battery itself. Colud this have damaged something by jump starting this way? Dont think it wold but Just wanted to make sure you knew this in case it made a difference.
Thanks
Sep 3, 2009 at 12:43 PM
JDL
  • 16,098 POSTS
As long as it was hooked-up correctly, I don't think it matters.
Sep 3, 2009 at 1:09 PM
