2004 GMC Yukon encoder motor
2004 GMC YUKON
93,000 MILES • V8 • 4WD • AUTOMATIC
MELANIECENGERI
i recently broke my transfer case and the one we replaced it with does not have the right connections so we just left the 4 wheel drive disabled and only drive in two wheel i thought that was fine although now my encoder motor is broken and i don't know what that is and if i really need to have it fixed or not is the car safe to drive w/ it broken?
thanks Melanie
Dec 16, 2008 at 11:57 AM
JAMES W.
  • 2,394 POSTS
The encoder motor shifts your transfer case in and out of 4whl drive and hi/lo range. Is it problem with bolt pattern or the electrical connections, that you can't change E motors?As long as the E motor isn't leaking case fluid, there's no harm or danger in driving. You just won't have range selection.
Dec 16, 2008 at 1:45 PM
MELANIECENGERI
I believe it is the electracal connections that are wrong but as long as it is ok to drive i think i will hold off getting it replaced till after the hollidays thanks so much
Dec 16, 2008 at 4:43 PM
JAMES W.
  • 2,394 POSTS
OK, if we can help any further, you know where to find us. Have a nice Christmas.
Dec 16, 2008 at 7:17 PM
