2004 GMC Yukon Door lock and window inop
2004 GMC YUKON
88,000 MILES • V8 • 4WD • AUTOMATIC
TOOL33PT
My Yukon Denali is having door lock issues. The door lock remote will lock all doors, but when unlock is pushed only the front driver and passenger door open. I can hear the that each other door, including the rear door are trying to work, but don't open.
Also the passenger side front door window doesn't role down. When you push the automatic button the motor makes noise but the window doen't move.
Any help would be appreciated.
Thanks,
Jess
Oct 15, 2009 at 11:27 AM
BRIAN 1
  • 1,030 POSTS
both rear door lock actuators are stuck,very common.as far as the window you will probably find the window regulator broken,which was also very common.
Oct 15, 2009 at 9:02 PM
