2003 GMC Yukon phantom heated seat
2003 GMC YUKON
45,000 MILES • V8 • 4WD • AUTOMATIC
RANDY B
The problem im having is the drives side heated seat seems to have a mind of its own. the heat randomly turns itself off and on and will cycle thru the low medium high settings , i turn it off and it turns itself right back on. I have taken it to the dealer and they have replaced the switch numerous times with no success. This seems to be an intermittent problem because it only happaens about 60% of the time. Saddly there is no fuse or any way to just dissconnect the heat. Is this anything you might have come across before? thanks for your help, randy
Mar 26, 2008 at 6:27 PM
RIVERA76
Randy,
Did you ever find out what your problem was? I have the same problem.
Dominick
Jan 2, 2009 at 4:43 PM
