2002 GMC Yukon Replacement Engine
2002 GMC YUKON
175,000 MILES • V8 • AWD • AUTOMATIC
MIKEMALONEY
This is a great vehicle but I know that the miles on the engine will be taking their toll. Two questions: what's the typical replacement cost of an engine and while it is probably a good idea to change out the transmission, too, my budget is only so big. Am I asking for trouble just doing the engine alone? The current motor runs very well, no seal leaks or obvious lack of compression. It's just gettin' a lot of highway miles.
Oct 2, 2010 at 2:29 PM
FACTORYJACK
  • 4,159 POSTS
It is dependant upon what you desire for an engine. A crate motor from GM, or a rebuild from an aftermarket source. You would not necessarily be asking for trouble doing the engine alone, if your maintenance has been adequate with the trans, and you adhere to the towing capacities and such. With a vehicle of that kind of miles, anything is possible. Other things to be concerned with are the rear differential, front differential, transfer case, and electrical.
Here is the parts and labor info for engine replacement. Of course the labor rate is going to vary shop to shop, but it will give you an idea. The (engine) is O.E., and it might be a new part price, as opposed to factory reman.
Parts Information
Part OEM Part Price
Engine
Engine
Engine Code N 89018179 $4403.36
Engine Code U 89018180 $4193.68
Contact dealer for most current part and price information.
Labor Skill
Level Mfg.
Warranty Standard
Engine
Diagnose/Test
Oil Leak, Diagnosis B 0.0 1.0
Replace
Complete Assembly Without Transfer Of Parts
Manual Trans B 6.6 9.4
Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
Auto Trans B 8.4 11.8
NOTE
With A.I.R., Add B 1.1 1.2
With Oil Cooler, Add B 0.1 0.1
With Three Piece Engine Cover, Add B 0.1 0.2
Complete Assembly With Transfer Of Parts
Manual Trans B 6.5 11.4
Includes: Transfer All Fuel & Electrical Units. Does Not Include: Transfer Of Optional Equipment.
Auto Trans B 9.3 14.8
NOTE
Long Block
Manual Trans B 0.0 16.8
Includes: R&I Engine And Transfer All Necessary Components Not Supplied With Long Block.
Auto Trans B 0.0 20.2
NOTE
With A.I.R., Add B 0.0 1.2
With Oil Cooler, Add B 0.0 0.1
With Three Piece Engine Cover, Add B 0.0 0.2
Short Block
Manual Trans A 0.0 19.8
Includes: R&R Engine And Transfer All Necessary Components.
Auto Trans A 0.0 23.4
NOTE
With A.I.R., Add A 0.0 1.2
With Oil Cooler, Add A 0.0 0.1
With Three Piece Engine Cover, Add A 0.0 0.2
To Grind Valves, Add A 0.0 3.0
Oct 2, 2010 at 10:44 PM
