Resetting Change Oil light
2001 GMC YUKON
107,000 MILES • V8 • 4WD • AUTOMATIC
BFLF5WZ
How do you reset the "Change Engine Oil" indicator? Is there a reset button somewhere, or another trick to it? Thanks.
Mar 30, 2008 at 10:02 AM
SERVICE WRITER
  • 9,123 POSTS
Turn the key to the on position, pump the accelerator 3 times within 5 seconds and it should start flashing, then stop. IT should be set at that point. This guide can help as well.
https://www.2carpros.com/articles/oil-life-reset
Mar 30, 2008 at 10:14 AM
