1999 GMC Yukon fuel injection system
1999 GMC YUKON
123,999 MILES • V8 • 4WD • AUTOMATIC
MICKEYP67
if you change the control module do you have to reset the fuel pump.
Oct 16, 2010 at 11:58 AM
JDL
  • 16,098 POSTS
I'm not sure I understand your question? What is the problem?
Oct 16, 2010 at 12:08 PM
MICKEYP67
[quote:917d68a20f="JDL"]I'm not sure I understand your question? What is the problem?[/quote:917d68a20f]
A mechanic replaced muy control module and claims that the fuel pump needs replacing, but he never reset the vehicle after he did it. He took apart the fuel line under the hood. the truck tries to crank up but can't since the line under the hood is apart. i took a loose the battery and put it back on and i hear the pump. he took out th4e two metal lines up top that fit into two holes near the injection system. need help told him to stop working on truck because i fear that he is messing up my truck.
Oct 16, 2010 at 1:12 PM
