1997 4wd two door yukon. Auto trans shift on the column. The shift lever is stuck in park. If I try long enough and push the brake several times I can get it to work and sometimes it just works normally. When I can get it out of park everything else is fine. It shifts through the gears fine and drives fine. Any suggestions. Thanks Gary
Aug 8, 2007 at 4:39 PM
