1996 GMC Yukon Starter periodically fails to activate
1996 GMC YUKON
YUKONLOVER1
Electrical problem
1996 GMC Yukon V8 Four Wheel Drive Automatic 115K miles
After several weeks or a month, the starter fails to activate; it just clicks. I clean the battery terminals and the problem goes away for another few weeks. The battery and positive battery cable to the ECS have been replaced.
Nov 18, 2009 at 3:35 PM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd check the actual voltage reading at the starter relay circuits, in the power distribution center under the hood. Unplug the relay and use digital voltmeter. Make sure the tranny is in park or neutral and the e-brake is set. Voltage to load side of relay is hot all the time. Voltage to coil side of relay goes hot with key in the start position.
Nov 18, 2009 at 4:26 PM
