1996 Yukon SLT, 5.7L, 4WD, 112,600mi. No Courtesy Lights. No exterior mirror control. No Daytime Running Lights(DRL). All other lights, dash lights, pwr seats/door locks/windows, radio, and RKE work fine.
Fuse #3(20 amp), in drivers side panel, will blow immediately when replaced. All other fuses appear to be good. Voltage on fuse #3 slot checks at 12.52 and about 38 amps.
There was no warning or intermittent failure prior to complete failure. I suspect the DRL system but not sure what to do about it. Is the DRL control under the dash? Can it be unplugged? There doesn’t seem to be much info on this kind of problem.
Thank you.
Thank you.
Jan 29, 2008 at 4:29 PM
