1996 GMC Yukon
1996 GMC YUKON
325,000 MILES • V8 • 2WD • AUTOMATIC
ABRAMS
Was driving vehicle at 50 mph and the engine died. Just before it died I cranked it over the enginge started and I proceeded down the road, it hesitated/stumbled twice and died. Prior to this no noticeable problems remembered. After it died I crank the engine over coughed (not a back fire) back up through the carboration unit. Cranks over when ignition is turned on but will not start. What could be the causes
Oct 19, 2009 at 10:12 AM
SERVICE WRITER
  • 9,123 POSTS
This will give you an overview.
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
You can spary some carb cleaner in the throttle body and then crank it. This may help confirm fuel loss.
IF this happens, I would next check fuel pressure to see if it goes into spec if I can hear the pump energize.
If good check for loss of spark with a spark tester.
Post your findings.
Oct 19, 2009 at 1:48 PM
