1995 GMC Yukon will not stay running
1995 GMC YUKON
131,000 MILES • V8 • 4WD • AUTOMATIC
SABRESMEDIC
the truck will start but will not stay running. you push done on the gas paddle and it will stop running. will iddle for a min or two. if you put it in gear and try to go any where the started to cut out and then stops running.
May 3, 2008 at 7:11 AM
Start by checking the idle air control valve/throttle position sensor and manifold absolute pressure sensors to include the fuel pressure-
May 3, 2008 at 8:11 AM
