1995 GMC Yukon little heat
1995 GMC YUKON
210,000 MILES • V8 • 4WD • AUTOMATIC
DERRICK MOORE
i have very little heat i put new heater core new t stat new heater water vale and a water pump and a leak test for a head gasket pleas help
Nov 30, 2008 at 2:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
When you say little heat, you refering to heater blowing cool air or that air flow is not present?
Nov 30, 2008 at 4:03 PM
DERRICK MOORE
when i say little heat i mean that the inside of the truck dos not get hot it just get warm it all started when the water pump was replaced so i thought that the water pump was bad so i put a gm pump on last wk the first pump was put in about 3mos ago it was not a gm pump it was from napa i think that the air flow could be bettet
Nov 30, 2008 at 5:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
How is the temp. gauge reading? Running to normal temp? Does the control switch adjust the heat temp. cooler and warmer or does the heat stay at the same temp ?
Could be possible resistor if controls not working, or switch itself is faulty.
Nov 30, 2008 at 6:18 PM
