My problem started when I started getting black smoke from the exhaust so i thought change the spark plugs which were very fowled just to get it home .
but still black smoke so i changed the fuel injectors still hard to start so to make a long story short .
I have replaced : the spark plugs,the wires distributor,rotor, the ignition coil,EGR solenoid ,and fuel injectors and it still won't start .
So I'm thinking it maybe it's the Fuel Injector Pressure Regulator because i get a stream of gas not a mist like it should be .
I'd like to know if I'm right .
AS OF 3/3/09
well i blew out the return line for fuel and it started rough but it was running .
Now it won't start at all .
i get it to turn over but it just won't start i have checked everything i can think of .
I checked or replaced the list below.
(REPLACED) spark plugs,the wires distributor,rotor, the ignition coil,EGR solenoid ,and fuel injectors .
(CHECKED)all the connections ,Battery,starter,fuel pressure, blew out the fuel line
Please help
thank you for your time
AS OF 3/3/09
Please help
Mar 15, 2009 at 9:00 AM
