2002 GMC Truck loose axles
2002 GMC TRUCK
226,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALTERED
right side axles is verry loos going in to the tranfer case
Jan 18, 2009 at 2:39 AM
MICKEY-D
  • 304 POSTS
The axle does not go into the transfer case, it goes into the differential, of which you have two. There is a front and a rear differential. Also, describe loose. Does it engage with the spider gear, will it turn the drive shaft?? You should be able to see if it's working by watching the gears as someone turns the axle. If it turns things, it's OK.
Jan 6, 2010 at 6:32 PM
