2000 GMC Truck Stopped running going down the road
2000 GMC TRUCK
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DREWZ4FUN
stopped while running. alt bench tests ok, swapped battery, gets fuel by bypassing filter. #1 plug sparks from plug to block as a test
Oct 15, 2009 at 6:50 PM
MICKEY-D
  • 304 POSTS
Try spraying a little starting fluid in the intake while cranking the eng. If it starts, you have either a plugged fuel filter, insufficient fuel pressure, or a bad pressure regulator.
Dec 31, 2009 at 10:17 PM
