1998 GMC Truck REMOVAL OF BRAKE DRUMS
1998 GMC TRUCK
75,000 MILES • V8 • 4WD • AUTOMATIC
EP
How do i back off the brakes to remove the drums
Dec 30, 2008 at 9:19 AM
MICKEY-D
  • 304 POSTS
I'm sure you already did the job, but here goes. There should be one or two slots in the rear backing plates with little rubber plugs. Pull out the plug, look inside with a light, push a screwdriver against the flat looking steel plate, push it away from the geared wheel, and turn the geared wheel with either a flat screw driver, or a brake adjusting tool until the drum spins freely. the drum should come off.
Jan 6, 2010 at 7:04 PM
