1997 GMC Truck AC air warm
1997 GMC TRUCK
165,000 MILES • V8 • 4WD • AUTOMATIC
BUELLGUY
  • 4 POSTS
System holds 27in Hg of vacuum after 30 min.of evacuation and In trying to recharge low and hi side pressure are 60psi low & 120psi hi when compressor is engaged & 90psi low & 70 hi when not, Line going to evaporator is warm when compressor is not engaged and cool when is it possible that orifice is plugged also causing back pressure @ hi side service port?
Jul 20, 2010 at 9:18 PM
DR LOOT
  • 2,311 POSTS
What do you mean by "causing back pressure @ hi side service port?" and I will ask you one more thing why did you evacuate the system? did you have a malfunction with the compressor? what went wrong in the system begin with.
Jul 21, 2010 at 12:56 AM
