1997 GMC Truck
1997 GMC TRUCK
168,000 MILES • V8 • 4WD • AUTOMATIC
PROPACK
I cannot get my truck to pass the emissions test. The test stops at the o2 sensor and the printout says unsupported. I have had the dealer install updates in the pcm and eventually replace the pcm. They told me to start the truck in the morning put it in drive with the air conditioner running for 5 minutes and this will reset the new pcm. Sounds fishy. I have had this truck inspected 5 times and am getting frustrated. Also as a side note, the service engine soon light does not work.
May 22, 2009 at 10:25 AM
DR LOOT
  • 2,311 POSTS
let me make sure I understand you, what you're trying to tell me is when you go get its smog, the smog guy tells you that some of the systems read "not ready" is that correct?
May 24, 2009 at 4:09 PM
