We have done almost everything we can and still haveing problems. The parts replaced is EGR, Idle position sensor, almost everything on the throttle body. it is tbi injected. The problem is mainly when it sits for about 8 hours or more, when starting it up it barely idles at 400 rpms. When running the fuel pressure is at 13 psi which the dealer said is right. The only other parts that haven't been replaced is the fuel regulator on the TBI and the fuel pump. After running a while it runs ok. Just don't get it. Both parts that haven't been replaced are GM original parts. This is my son's car and he said it takes about 30 + seconds when turning the key on (without starteing it) the pump makes two noises. I am thinking the fuel pump but don't want to have him have to replace the pump if we should replace the regualtor. Can you tell me what you think it may be? Thanks for any help you can give!
May 5, 2009 at 12:03 AM
