1991 GMC Truck No Fuel No Spark
1991 GMC TRUCK
TIMSPRKS
Engine Mechanical problem
1991 GMC Truck V8 Four Wheel Drive Automatic
1991 GMC 2500 350 engine. My wife was driving my truck to work and it hesitated a little like it was going to die but it made it. After she got off she tried to start the truck and it would only turn over but not start. I checked the fuel pump and it's getting fuel up to the carb but not to the injector port and i checked to see if it was getting spark and there is no spark. Any ideas on what i should do next ?
Jul 5, 2009 at 12:51 PM
JDL
  • 16,098 POSTS
If there is no spark at the plugs or injector pulse during cranking, I'd look for an rpm signal. Possibly the pick-up coil or ignition module. I'd check the wiring circuits before replacing anything.
Jul 5, 2009 at 1:25 PM
TIMSPRKS
I appreciate your input JD. Is this a hard thing to fix or is it something that myself, not knowing too much about vehicles, would be able to fix.
Jul 6, 2009 at 12:23 PM
JDL
  • 16,098 POSTS
Yeah, if your handy under the hood, you could do the work.
Jul 6, 2009 at 12:55 PM
