i shipped my GMC to germany from the states when i drop it off everything was find then when it got to germany i fueled up and about 1hr later the truck cuts off, about every 10mins i had to pull over turn the truck off then turn it back on you it will go above 1,000RPM i change the O2 sensor then it was better for about 30mins then started stalling again since then i have change the distributor cap, plugs&wires, Cataylic converter and i new set or O2 sensors again it was working fine then it starts to stall again after a few min. and it also its popping from the air filter. OBD II reads code UNKNOWN. i also replace the fuel filter... and before i sent it to germany a new fuel pump was installed
Dec 18, 2009 at 8:17 AM
